WebMeeting Change Params names
Discussion in '3CX Phone System - General' started by WANAO, Mar 6, 2018.
  1. WANAO
    Mar 6, 2018
    12
    Dear Community,
    I would like to know if it's possible to modify parameters name from Webmeeting email?
    See attached files
    Thank you.
    Regards,
      File size:
      15.8 KB
      5
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,448
    541
    Hello @WANAO
    Please note that the email templates can be found in Settings / Email / Email templates. You can also organise the conference using Gmail, Office 365 or ical and edit the invite before sending it out.
  3. WANAO
    Mar 6, 2018
    12
    Thank you for your reply.
    I just want to switch"3CX WebMeeting" by may company name, the one that will be registerd to my customer scheduler.
    I dont have this option on email templates.
    Thank you.
    Regards,
