Solved Webmeeting error
Discussion in '3CX Phone System - General' started by mattmoo138, Feb 23, 2018.
  1. mattmoo138
    Jan 26, 2018
    9
    HI
    Logged into my portal externally and all is fine, if i click on webmeeting i get failed to connect to server message. any ideas?
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    Try this: nslookup eu006-lon.3cx.net
    Should return:
    78.129.229.5
  3. mattmoo138
    Jan 26, 2018
    9
    Hey thanks for this, funny enough it just started working again, odd, thank you
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,326
    532
    Glad to see that the issue has been resolved.
