Webmeeting Portal Company logo
Discussion in '3CX Phone System - General' started by daktur, May 24, 2017.
  1. daktur
    daktur New Member
    Oct 15, 2015
    230
    8
    Hi all,
    What is the format and dimensions for the file to be used as the Webmeeting Portal Company logo?
    Thanks!
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    304
    hmm... not seeing it in the page source... or css.
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    In your 3CX PBX > Settings > Conferencing, Any generic image file format is accepted as your 3CX PBX Background Logo.
    Image size is restricted to 25mb max and dimensions can be anything you like, however a 120x120min - 1280x720 max is suggested, but not enforced.
    daktur likes this.
  4. msnyder
    Jul 20, 2017
    24
    What if the image does not display?
  5. TechJimF
    May 11, 2017
    23
    I have tried this too and still see the default 3CX logo.
  6. StefanW
    Jun 2, 2009
    1,222
    93
    it is important that the webmeeting portal can connect to your 3CX mangement console, as on the start of the meeting it will fetch the logo from your server (pbx)!
  7. TechJimF
    May 11, 2017
    23
    How would I know if it is connecting to the management console or not? When I schedule a web meeting from my portal, I can see the contacts on the 3CX system so I have correct ports open.
    Thanks,
    Jim
  8. Fabrice
    Aug 10, 2017
    The WebMeeting has to access the https picture URL in the provisioning folder, same folder that proisionning template
    I also noticed that my logo doesn't appear because of security features
    The logo URL in https (on the 3cx) has different certificate than the WebMeeting https URL
  9. TechJimF
    May 11, 2017
    23
    How can you tell if the WebMeeting has access or not?
    Sorry for all the questions, have no idea how to figure it out. The default 3CX logo shows up on the WebMeeting.
    Thanks,
    Jim
