Webmeeting server location
Discussion in '3CX Phone System - General' started by Maxime Croisetiere, Feb 21, 2018.
  1. Maxime Croisetiere
    Feb 21, 2018
    I am trying to use the WebMeeting option with my team but we have a poor video quality.
    I saw in the information of the webmeeting I am actually connected to the USA WestCoast server: USA West
    Coast (Seattle) - us008-sea.3cx.net (216.244.83.114) - CA Canada
    We are based in Montreal and our preferred server in our 3cx settings is set to the Montreal Server.
    How can I force the system to use Montreal server? Is it a problem on your side (server down for example)?
    Thank you very much,
  2. saqqara16
    Jan 13, 2016
    41
    5
    On the front screen, click on WebMeeting MCU (right hand side) and you can select another server
  3. Maxime Croisetiere
    Feb 21, 2018
    Hi! I am not sure where is the MCU option you talk about on the right hand side?
    You can see the screenshot of what I see attached.
      File size:
      36.1 KB
      8
  4. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    841
    125
    Option is within the 3CX admin console
  5. Maxime Croisetiere
    Feb 21, 2018
    Thank you Saqqara, maybe I am not looking at the right place, but in the 3cx admin console, my MCU is already set to Montreal.
    Unfortunately, when I start a webmeeting, the selected server is Seatle. I don't understand why!
      File size:
      47.8 KB
      7
  6. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,399
    79
    This is how it works. I hope this clears it up a bit and not make it more confusing.
    Part 1: The PBX, the MCU and you
    • Install your PBX somewhere in the world.
    • Your PBX's IP is then geolocated. Then assigned the geographically closest MCU to your PBX.
    Part 2: QuickMeeting
    • Each extension on your PBX has a meeting called "quickmeeting" by default.
    • This meeting will always use the MCU you set in your PBX's Conference Settings.
    Part 3: Other Meetings
    • When new meetings are created manually, they are created using whatever is MCU you set in your PBX's Conference Settings.
    • Alternatively, users can also specify during meeting creation, which MCU they want that specific meeting to take place on.
    • Once the meeting has been created, changing your default MCU that is set in your PBX's Conference Settings will NOT change what MCU already existing meetings use.
    • The setting in the PBX's Conference Settings is merely a default/suggested MCU on which all meeting creations are based on from the point you've selected some X MCU.
