WebRTC documentation?
Discussion in '3CX Phone System - General' started by engtech, Mar 1, 2015.
  1. engtech
    Jun 28, 2014
    I am excited to play around with WebRTC. I did the whole backup/unintall/re-install/restore upgrade from 12 to 12.5 last night. I am using a FQDN and have added the new/updated ports for 12.5/WebRTC from here http://www.3cx.com/blog/docs/ports-used/ but I just can't get it to work.
    I decided to go read the documentation and see what I was missing. I pulled up the 12.5 administrator manual and searched for webrtc and there were NO matches. I've also searched the 3cx site and google extensively for 3cx webrtc setup/config etc. and all I can find are pages where 3cx touts all the wonderful features and capabilities of WebRTC but not a damn thing about how to set it up or configure it. This is maddening.
    My "trunk status" for Webrtc has been showing up as "unregistered" and I couldn't find a way to change that. I rebooted the server just for the heck of it and nothing change. Several hours later, it finally switched to a registered status on its own, but my webrtc call links still don't seem to be working. When I paste a link into my browser from a remote location, Chrome just says "establishing secure connection" and then times out. When I try it locally, from Chrome on the computer that is the 3cx server and replace the fqdn with "localhost" or 127.0.0.1 I still get the exact same result, so I think that rules out a port forwarding issue. My firewall on the 3cx server PC is disabled. Maybe I'm missing something. It's entirely possible given what appears to be a complete lack of documentation.
    Thanks if anyone can help shed some light on this.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    I think the cause of this issue can be found in the certifying of the used Web Server, Abyss or IIS.
    I almost exactly encounter the same issues as you have.
    If you can skip the error message of Chrome then a user screen will load for the 3CX WebRTC.
    Click the green phone icon and the extension will ring. The “Trunk Status” for WebRTC will go green also.
    In my case if the call is accepted there is no audio or video both ways. Tested with notebooks-deskphone and notebook-notebook.
    Now I am trying to create a real (no self-signed) certificate, but I don’t know how to do that with an Abyss server. I think 3CX have locked the web server somehow.
    See my post: http://www.3cx.com/forums/abyss-ssl-tls-certificates-40985.html
    BTW: there are more forum member who have trouble with the WebRTC.
  3. cjtrevor
    Feb 9, 2012
    73
    8
    I get as far as the 3cx screen saying to press the green call button, but when I press it nothing happens. Couldn't find anything in the manual so gave up!
  4. mccord
    Feb 8, 2011
    I would be interested in documentation as well. To the best of my knowledge, I have set up everything correctly and opened the correct ports in my firewall. I get the screen and click the green call button and nothing happens.
    Thanks!
  5. mahe23
    Apr 28, 2009
    23
    Hallo,
    1. I have WIN SERVER 2013 with IIS
    2. WebRTC Gateway Is set Hotname: 127.0.0.1 Port 5062
    3. EXT FQDN is set to Routers ext. IP and INT FQDB to IP of 3CX
    4. Port-/Trunk-status Gateway webrtc is red
    What schall I do / test?
    Matthias
  6. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Looks like WebRTC in V.14 is working better.
    For V.12.5 I found a way around to force WebRTC trunk to register is to disable temporary registration and turn on back again, in most cases the trunk will remain registered. Also using a domain name instead of IP address improves behavior.
    Regards
  7. ethisec
    May 30, 2015
    I'm seeing the same problem here too, even with a legitimate (correctly installed) certificate on an IIS web server.
    Where exactly do you disable temporary registration?
    Jason
  8. danielevz
    Jul 6, 2015
    5
    for audio to work you must disable STUN in settings, network.
  9. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Really? I was just told by my provider to turn STUN on for a more reliable experience. So have I now broken WebRTC?
