WebRTC for V15?
Discussion in '3CX Phone System - General' started by bseddon, Sep 21, 2016.
  1. bseddon
    Sep 13, 2016
    12
    I can see there is support for initiating calls from a web page in V14 and there is a section in the admin manual (http://www.3cx.com/docs/configure-webrtc/) covering this. But the same section does not appear to exist in V15.
    Is this a change in available functionality or have a just missed the relevant documentation?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,445
    540
  3. bseddon
    Sep 13, 2016
    12
    Gosh, thanks for the link. That's unfortunate. I'll look for a solution a different way. I've been delighted by the 3CX V15 server which has been easy to setup and use. Obviously a lot of effort has gone into 3CX. So someday maybe the back story on the removal of webrtc feature will be told.
    The Chrome extension you suggests only works if the prospective caller is already using the 3CX client so not applicable to the use case I have in mind. But thanks anyway.
  4. bseddon
    Sep 13, 2016
    12
    Do you have any experience with this tool:
    https://github.com/DoubangoTelecom/sipml5
    It seems to claim it's possible to initiate a session using SIP from a [HTML5] web page. If so this could be a viable candidate since the 3CX server is SIP server and we could block attempts to access the server that do no include valid referer credentials.
