WebRTC problem.
Discussion in '3CX Phone System - General' started by BesOn, Jul 26, 2017.
  1. BesOn
    Jan 21, 2016
    17
    Dear, community members and 3CX staff.
    I have configured 3CX WebRTC on our company, but problem is - no sound (caller, destination)
    Version of 3CX is 14 SP3
    STUN server is disabled.
    Firewall rule on 3CX server created (ports 9000 - 9500 UDP allowed)
    Tried both browsers Chrome and Firefox.
    I am trying to call also from internal network, without proxy and firewalls. Call establish but no sound again.
    Here some logs from Activity Log
    26-Jul-2017 16:24:00.627 [CM503025]: Call(C:4696): Calling T:Extn:1010@[Dev:sip:1010@10.50.0.131:5060;transport=UDP,Dev:sip:1010@10.46.3.100:30579;rinstance=0-69094839060e43678e7044d0489e6765;ob] for L:4696.1[Line:90000<<WebRTC]
    26-Jul-2017 16:24:00.623 [CM503025]: Call(C:4696): Calling T:Extn:1010@[Dev:sip:1010@10.50.0.131:5060;transport=UDP,Dev:sip:1010@10.46.3.100:30579;rinstance=0-69094839060e43678e7044d0489e6765;ob] for L:4696.1[Line:90000<<WebRTC]
    26-Jul-2017 16:24:00.615 [CM503027]: Call(C:4696): From: Line:90000<<WebRTC ("WebRTC (10.46.3.100)" <sip:WebRTC@3cx._______.com:5060>) to T:Extn:1010@[Dev:sip:1010@10.50.0.131:5060;transport=UDP,Dev:sip:1010@10.46.3.100:30579;rinstance=0-69094839060e43678e7044d0489e6765;ob]
    26-Jul-2017 16:24:00.615 [CM503004]: Call(C:4696): Route 1: from L:4696.1[Line:90000<<WebRTC] to T:Extn:1010@[Dev:sip:1010@10.50.0.131:5060;transport=UDP,Dev:sip:1010@10.46.3.100:30579;rinstance=0-69094839060e43678e7044d0489e6765;ob]
    26-Jul-2017 16:24:00.615 [CM505002]: Gateway:[webrtc] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX WebRTC proxy] PBX contact: [sip:90000@127.0.0.1:5060]
    26-Jul-2017 16:24:00.614 [CM503001]: Call(C:4696): Incoming call from Line:90000<<WebRTC to <sip:1010@10.50.0.5:5060>
    26-Jul-2017 16:24:00.614 Line limit check: Current # of calls for line Lc:90000(@webrtc[<sip:90000@127.0.0.1:5062>]) is 1; limit is 25
    26-Jul-2017 16:24:00.614 NAT/ALG check:L:4696.1[Line:90000<<WebRTC] REQUEST 'INVITE' - basic check passed. No information for extended checks
    11,111
    329
    How many devices (different computers) have you tried this between? Could it be a PC sound card/device issue? Did you run the 3CX Firewall test with all tests passing?
  3. BesOn
    Jan 21, 2016
    17
    Problem is not in devices, because we have IP phones too. Tried on 3 computers and 2 IP phones. Mics and headphones also working properly
  4. BesOn
    Jan 21, 2016
    17
    We can not run firewall checker, because people is working with 3CX. UDP ports 9000 - 9500 opened.
