- Joined
- Aug 8, 2015
- Messages
- 2
- Reaction score
- 0
Hello @all,
I've encountered a strange problem which I can't fix by documentation.
Since today in the morning, my V.14RC WebRTC won't work anymore. Log shows the password to be incorrect. It says in the Activity Protocol:
I don't see which passwords I should get to match here, though.
It repeats the login every few seconds, so the log is full of messages like this:
In the System - Trunk Status, webrtc gateway is accordingly shown as red. Is there a way to fix this so easy I didn't see it?
I'm grateful for any help on this.
Best regards,
m99
Credentials don't match, check that authorization-ID and password match the ones in extension settings
08-Aug-2015 20:13:32.241 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 127.0.0.1:5062 tid=8305a058657c947f Call-ID=Yzg4ODE1ZDAwODY2NzU3NWYyOGEzYjIzOTI1MjdiYjE.:
REGISTER sip:127.0.0.1 SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5062;branch=z9hG4bK-d8754z-8305a058657c947f-1---d8754z-;rport=5062
Max-Forwards: 70
Contact: <sip:[email protected]:5062;rinstance=b5f1fe0308c368c7>
To: <sip:[email protected]>
Call-ID: Yzg4ODE1ZDAwODY2NzU3NWYyOGEzYjIzOTI1MjdiYjE.
CSeq: 2 REGISTER
Expires: 60
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Proxy-Authorization: Digest username="90000",realm="3CXPhoneSystem",nonce="414d535c0bd6d7cc69:68d3411967ae0b6ee7ecac79542e0f63",uri="sip:127.0.0.1",response="68302d9631a4da08ad826dc0c6b52116",algorithm=MD5
Supported: replaces
User-Agent: 3CX WebRTC proxy
Content-Length: 0
; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
Best regards,
m99
