WebServices - third party integration
Discussion in '3CX Phone System - General' started by Anonymous, Oct 12, 2006.
  1. Anonymous
    Anonymous Guest
    I was wondering if there are any talks to allow for third party developers to integrate with the PBX system through some type of xml web services.
    I think it would be nice to be able to build some basic web pages that get and display pbx information.
    It would also be nice to have a Call Assistant software offering to allow for easy transfering of calls to other extensions, etc. Other SIP systems have very nice ones like Allworx.
    With the ability to tie into PBX information someone could build a fat client that displays the directory listing and each person's status, be able to transfer calls by dragging and dropping.. etc.
    Just a thought.
    -Mark
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    309
    API - client
    Hi Mark,
    We are in the progress of developing a Windows client which has these types of features. Probably we will also create an API at the same time but at present we are focusing on the release of our product. By January we should have a client with API though....
