Website Click to Call*Discussion
Discussion in '3CX Phone System - General' started by bduke08021, Aug 27, 2010.
  1. bduke08021
    Jun 20, 2009
    34
    Is their a way to put on my website a button for someone to click and have the phone system connect a rep to them?
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Re: Website Click to Call
    See this article about making calls using the http api.
    http://www.3cx.com/blog/docs/3cx-http-api/
    You will need to know the extension number that will call them
  3. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    667
    7
    The simplest way is to use http://www.flaphone.com/?lang=en (free Callme Widget) and two SIP accounts.
    The first one you attach to 3CX, the second to Flaphone. Then Flaphone calls to 3CX. Thats all!
  4. bduke08021
    Jun 20, 2009
    34
    I tried both suggestions, The Flaphone works but the person is calling from their computer, i would like for the to input their number and click a button that would say call me and have a ext or ring group call them.
  5. abc123
    Nov 9, 2009
    712
    The api meets your requirements.
    They type in a number in a text box on your page and you use the api to call that number from an extension.
    If you want to get it to ring a group first then create a dummy extenstion (e.g. 900) and have that set to forward all calls to the ring group/queue and put the ext. (900) in the api call.
