Solved Weebmeeting video from cellphone
Discussion in '3CX Phone System - General' started by stewart1977, Nov 15, 2017.
  1. stewart1977
    Jun 29, 2017
    11
    Hi i have a problem with my webmeeting. It seems i can not send or receive the video or audio in webmeeting i see my video but no other.
    update
    ok its a port problem in pfsence i have all the ports open that are on the website of 3cx but there must be another one not listed. eg when i tell pfsence to let any port in and out on lan side it works on everything can see all video. if i tell pfsence to only let the ports open that are on the website only it will not send or receive any video or audio. Please can you tell me the ports that are needed to send audio and video througth webmeeting. thanks
    #1 stewart1977, Nov 15, 2017
  2. stewart1977
    Jun 29, 2017
    11
    fixed it port 4443 needs to be open on lan side
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,444
    463
    Glad to hear the issue is resolved and thank you for sharing your solution
