Weird connection attempt in server log
Discussion in '3CX Phone System - General' started by daktur, Nov 16, 2015.
  1. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    Hi Everyone,
    I found many attemps of connection from different Extensions that doesn´t exist:
    16-nov-2015 13:10:05.278 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 212.83.146.50:5088 tid=251891c5cab756455648ae3b Call-ID=1c5c9cc-d855641-5648ae3a@74.208.125.179:
    REGISTER sip:74.208.125.179:5060 SIP/2.0
    Via: SIP/2.0/UDP 212.83.146.50:5088;branch=z9hG4bK251891c5cab756455648ae3b;rport=5088
    Max-Forwards: 70
    Contact: "6146"<sip:6146@212.83.146.50:5088>
    To: "6146"<sip:6146@74.208.125.179:5060>
    From: "6146"<sip:6146@74.208.125.179:5060>;tag=251891c620fc
    Call-ID: 1c5c9cc-d855641-5648ae3a@74.208.125.179
    CSeq: 2 REGISTER
    Expires: 1800
    Proxy-Authorization: Digest username="6146",realm="3CXPhoneSystem",nonce="414d535c0c5a82cd02:3cc31366fe275097a578873e273131ff",uri="sip:74.208.125.179",response="8ffbb3440fce36a0aabfe5c9f536c1a7",algorithm=MD5
    User-Agent: VaxSIPUserAgent/3.1
    Content-Length: 0
    ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    16-nov-2015 13:09:47.231 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 212.83.146.50:5086 tid=230571c5844556075648ae28 Call-ID=1c5834b-c855607-5648ae28@74.208.125.179:
    Via: SIP/2.0/UDP 212.83.146.50:5086;branch=z9hG4bK230571c5844556075648ae28;rport=5086
    Max-Forwards: 70
    Contact: "2850"<sip:2850@212.83.146.50:5086>
    To: "2850"<sip:2850@74.208.125.179:5060>
    From: "2850"<sip:2850@74.208.125.179:5060>;tag=230571c5da4c
    Call-ID: 1c5834b-c855607-5648ae28@74.208.125.179
    CSeq: 2 REGISTER
    Expires: 1800
    Proxy-Authorization: Digest username="2850",realm="3CXPhoneSystem",nonce="414d535c0c5a82ba68:f245ff72e451e9a78a986fe128664e2e",uri="sip:74.208.125.179",response="84c700f97b7ae6376cae890ae872e52b",algorithm=MD5
    Content-Length: 0
    Is that correct? Should I ban this IP in the Anti hacker option?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    You will find that as time goes by there will be many attempts to hack into the system. You need to insure that all passwords are strong and that you have the parameters set up for the security to your liking. Yes, you can also blacklist the IP manually within 3CX or perhaps even in your router.
  3. Twobrothers
    Nov 18, 2015
    I am faced with this same problem.
  4. leejor
    10,732
    277
    A long time back, I set the blacklist time-out very high, something in the order of 25,000 seconds. I also made sure that I got an email every time there was a blocked registration attempt. If there are repeated attempts from certain IPs, or IP ranges, I blacklist them permanently. Theses sorts of things still occur but over time there has been a drastic reduction.
