Solved Weird inbound call timeouts (3cx sleeping)
Discussion in '3CX Phone System - General' started by Sampl, Jan 17, 2018.
  1. Sampl
    Jan 4, 2018
    27
    5
    i am experiencing a rather weird behavior on our 3CX system.
    after a while more then an hour or so inbound calls will no longer happen until i make an outbound call first to wake up the trunk or something.
    internal calls and outbound calls always keep working.
    is there a setting that keeps the trunk alive?
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Have you run 3CX firewall checker and what is the result ?
  3. Sampl
    Jan 4, 2018
    27
    5
    Ah, nice one.
    am reading the documentation now on the following errors.
        • testing 3CX SIP Server... failed (How to resolve?)
          • stopping service... done
          • detecting SIP ALG... detected (received ***********) (How to resolve?)
          • testing port 5061... full cone test failed (How to resolve?)
          • starting service... done
        • testing 3CX Tunneling Proxy... done
          • testing port 5090... done
        • testing 3CX Media Server... failed (How to resolve?)
          • testing ports [9000..9255]... failed (How to resolve?)
    everything after that was green.
  4. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
  5. sip.bg
    Nov 7, 2016
    704
    220
    Try fixing the issues into your router, 99.9% this causes the "sleep" effect, if using a supported provider, but not only.
  6. Sampl
    Jan 4, 2018
    27
    5
    Cool! i disabled SIP ALG on our firewall and it helped all but 1 issue the firewall checker was reporting.
    • resolving 'stun-au.3cx.com'... done
    • resolving 'stun2.3cx.com'... done
    • resolving 'stun3.3cx.com'... done
    • resolving 'sip-alg-detector.3cx.com'... done
      • detecting SIP ALG... not detected
    • testing 3CX Media Server... done
      • testing ports [9000..9255]... done
        • testing port 9000... done
        • testing port 9001... done
        • testing port 9002... done
    working on that part and will let you know what the results are.
    Thanks!
  7. sip.bg
    Nov 7, 2016
    704
    220
    What make is your router and does it have any built-in phone ports ?
    Some routers have built-in VoIP functionality and utilize ports 5060, 5061.
    If so, you need to disable them or change ports used (e.g. to 5160, 5161).
  8. Sampl
    Jan 4, 2018
    27
    5
    i have Sophos XG210 firewall
  9. sip.bg
    Nov 7, 2016
    704
    220
  10. Sampl
    Jan 4, 2018
    27
    5
    Hi Guys,
    the issue has been fixed.
    it was settings on our firewall i had our IT service provider (WAN Managers) have a go at it at some point yesterday and they have informed me that the issue is now fixed, which i can confirm. i will give them a call on Monday for the explanation on how they fixed it and post that here.
    Thanks for your help!
  11. apostolis_3CX
    Nov 1, 2017
    149
    15
    Hi Sampl,
    Glad to hear your issue was resolved.
    We will be waiting for your feedback.
  12. Sampl
    Jan 4, 2018
    27
    5
    Hi All,
    so what fixed the final port issue we were having was to unload the SIP Helper as well.
    Thank you all for the help!
