Welcome e-mail
Discussion in '3CX Phone System - General' started by Lucian, Jan 4, 2017.
  1. Lucian
    Jan 4, 2017
    9
    Hi! After I install 3CXPhoneSystem15, I add 2 extensions with different e-mails. I send for both extensions Welcome Email, but i didn't receive nothing. Does anyone know why?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,890
    495
    Hello @Lucian,
    Did you set up an smtp server in the email settings? Have you checked if your credentials are correct?
  3. Lucian
    Jan 4, 2017
    9
    Yes, i use smtp.gmail.com (server) and my gmail account.
    My credentials are correct.
    When i push the "TEST" button from Email Settings>Mail Server, i received this message
    • " The operation was canceled."
    #3 Lucian, Jan 4, 2017
  4. YiannisH_3CX
    May 10, 2016
    6,890
    495
  5. Lucian
    Jan 4, 2017
    9
    I did all steps exactly like in article until " it is required to login to Gmail at least once from the 3CX Server" (same with your advice). How can i do that?
  6. YiannisH_3CX
    May 10, 2016
    6,890
    495
    We mean open a browser and login into gmail from the physical machine not from the management console. Also disable any antivirus that might exist on the server and disable the windows firewall to eliminate anything blocking you
  7. Lucian
    Jan 4, 2017
    9
    I don't understand very well. I login into gmail from my physical machine (laptop) with a browser (like i normally do). Shouldn't t i login from management console?
  8. YiannisH_3CX
    May 10, 2016
    6,890
    495
    every time you login to gmail from a different machine gmail sents you an email to confirm that this is you and verify the machine. Logging in gmail from the PBX machine will allow gmail to verify the PBX machine and allow you to sent emails from there.
  9. Lucian
    Jan 4, 2017
    9
    Yes, this is clear for me, but i don't know how to logging in gmail from the PBX machine. If it's a section in management console, I can not find.
  10. YiannisH_3CX
    May 10, 2016
    6,890
    495
    I apologise for the miss-understanding I do not mean from the management console. I mean from the machine the Pbx is installed on.
  11. Lucian
    Jan 4, 2017
    9
    No problem!
    Pbx is installed on my laptop (windows 10), i don't have a different machine ( or a virtual one)
  12. YiannisH_3CX
    May 10, 2016
    6,890
    495
    ok i see. After following the guide do you still get the same error? Have you disabled antivirus and windows firewall for a test?
  13. Lucian
    Jan 4, 2017
    9
    Yes, i tried with antivirus and windows firewall disabled, same error :(
  14. YiannisH_3CX
    May 10, 2016
    6,890
    495
    @Lucian i have sent you a p.m.
  15. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    That could be a problem for users of 3CX iso image. They will need text-based email client like Alpine:cool:
