Welcome email not sending - other emails ok
Discussion in '3CX Phone System - General' started by alex22alex, Aug 30, 2017.
  1. alex22alex
    Jun 11, 2008
    38
    We cant resend, nor do any of our agents ever get a welcome email so they can use 3CX client. We running V15 and its confusing as other emails send correctly like extensions being registered, ips blocked etc so i dont think its email server settings.
    I have though check our server logs to see if its being spammed and thats also not the case. So i am stumped any ideas dudes ?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,514
    361
    Hello @alex22alex
    Since you get emails regarding that server status i would assume that the mailer is blocking emails with attachments as the other emails do not include attachments. So i would start from there, and make sure that attachments are not blocked on the mail server.
  3. leejor
    10,587
    253
  4. alex22alex
    Jun 11, 2008
    38
    Hello Dudes,
    I have tried my work smtp server and i have also tried my personal gmail account and the welcome email does not send on either though the test and other emails do.
    One thing i notice is the email template is blank in 3CX for "ext.Agent Welcome" though "Extension Welcome" is fine. The extensions that i am testing with are all local.
    I have also created a brand new extension, in case it was just an issue with resending old emails.
    Thanks. Alex
  5. daneke
    May 8, 2017
    46
    You checked junk mail?
  6. alex22alex
    Jun 11, 2008
    38
    @daneke yep as i said in my first comment i have checked to see if its being spammed
  7. Brian Cross
    Brian Cross New Member
    Jul 26, 2017
    109
    27
    If using gmail I think you need to enable less secure apps if I'm not mistaken.
    nb likes this.
  8. alex22alex
    Jun 11, 2008
    38
  9. Brian Cross
    Jul 26, 2017
    109
    27
    I think I had to go into settings/parameters and change the port number. It's been a while sorry.
  10. alex22alex
    Jun 11, 2008
    38
    I've set the port number ok for Gmail( didn't seem to be needed for normal email server) and I'm getting email notifications for things like trunks / extensions connecting so don't think it's issue with the sever?
  11. nb
    nb Support Team
    Jun 7, 2007
    2,117
    145
    You have to check on this one yourself. Voicemail emails are received for example? with attachments? Configure an extension with these settings from extension settings and leave a voicemail to this extension. See if the mail goes.
    The welcome email contains an attachment. Maybe there are some settings related to this. You have to go inside your mail provider and sort this out yourself. Nothing to do with 3CX.
  12. Carlson Leung
    Aug 30, 2017
    I got a message after downloading the 3CX about contacting the system administrator for the Welcome Email. Do I send an email to info@3cx.com?
    Carlson
  13. leejor
    10,587
    253
    The welcome email will be come from the administrator of the PBX you wish to have an extension on. You'll need to contact them.
  14. nb
    nb Support Team
    Jun 7, 2007
    2,117
    145
    Carlson Which 3CX product did you download? Based on your description it looks like you downloaded a client app. This is the server forum.
  15. Carlson Leung
    Aug 30, 2017
    sorry.... my bad
