welcome message dosent play
Discussion in '3CX Phone System - General' started by mstit, Mar 23, 2016.
  1. mstit
    Mar 22, 2016
    5
    Hi all.
    i have recorded a welcoming note in a audio program and saved it as *.wav file, but it wont get played when i call the queue. but when i use the record sound, built into 3cX, and i choose this new one, it will be played,
    is that a bug in the system or?
    11,129
    330
  3. mstit
    Mar 22, 2016
    5
    I dident save it as the guide says, i am using a hosted version, and i use the uploade method so the system should know where it need to be, but i want to here it over the 3cX it is as there is no sound in the file
  4. leejor
    11,129
    330
    It was the format of the file " You must save the file in WAV format in PCM, 8 kHz, 16 bit, Mono format. ", to which I was referring.
  5. mstit
    Mar 22, 2016
    5
    Error found, it was the change to 16 bit i have missed out. thx :)
