WellGate 2540 missing in 3CX Console
Discussion in '3CX Phone System - General' started by narkumas, Jan 26, 2018.
  1. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Hello 3CX Staff!
    I am missing the Welltech Wellgate 2540 4FXS in the Management console.
    Is it compatible wit the 2504 4FXS? I have a 2504 and would like to provision it with 3CX standard methods.
  2. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
  3. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,218
    174
    Look at the below, the FXS variant you are using is not supported:
    https://www.3cx.com/voip-gateways/
    You are not alone with this, beroNet FXS is not recognized as well as some Patton models.
    I would suggest (if you are comfortable with custom templates) taking the 24 port variant and adjusting this. I did the opposite sort of thing with the Patton 4112 JS (FXS) up to the un-supported 24 port channel bank and it worked fine.
    NOTE: Custom templates are not supported by 3CX.
  4. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Yeah, but the WellGate 2450 is supported!
  5. eddv123
    Aug 15, 2017
    1,218
    174
    You have said above you are using FXS not FXO:
    FXO = Analogue lines.
    FXS = Analogue endpoints such as phones, FAX and ringers.
    https://www.patton.com/technotes/fxs_fxo.pdf
    The 3CX support page states: Welltech WellGate 2540 – 4 port FXO and makes no reference to FXS. The FXO variant will appear in the "Trunks" page in 3CX.
    YiannisH_3CX likes this.
  6. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Ah, sorry. I missed the difference. Thank You for this information.
