Solved Welltech ATA172 Plus - Provisioning Issues
Discussion in '3CX Phone System - General' started by Michael Menor, Feb 16, 2017.
  1. Michael Menor
    Dec 30, 2016
    37
    Hi everyone,
    We're trying to setup a Welltech ATA172 Plus on 3CX V15 and I followed this guide, but I'm not able to see it listed as a phone after I complete the setup. When I log into the ATA itself, it shows the following in the Status Log:
    Index Message
    0 <2017-02-16 12:15>Stop searching Configured file!
    1 <2017-02-16 12:15>Get file Fail!!!
    2 <2017-02-16 12:15>HTTP Get file...
    3 <2017-02-16 12:15>Get file Fail!!!
    4 <2017-02-16 12:15>HTTP Get file...
    5 <2017-02-16 12:15>Get file Fail!!!
    6 <2017-02-16 12:15>HTTP Get file...
    7 <2017-02-16 12:15>Boot reason : web_reboot
    8 <2017-02-16 12:15>Get file Fail!!!
    9 <2017-02-16 12:15>HTTP Get file...
    10 <2017-02-16 12:15>Get file Fail!!!
    11 <2017-02-16 12:15>HTTP Get file...
    12 <2017-02-16 12:15>Server = [PBX IP], FileName = 0001A[MAC].dat
    13 <2017-02-16 12:15>Get Time from SNTP server, Succeed!
    I searched through the 3CX Forum and found this thread to manually create the .DAT file that the ATA is looking for, but that didn't help either..
    I've opened a case with 3CX Support (pending a response), but I figured I'd reach out to the Community for insight.
    I've attached screenshots of the Status Page and Provisioning Page.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,404
    282
    Hello @Michael Menor
    Have you populated both extensions when configuring the device as shown in step 3? If not please do and try again. If you do not need a second extension then add dummy for test.
  3. Michael Menor
    Dec 30, 2016
    37
    @YiannisH_3CX Assigning a second extension to the ATA worked. I think you guys need to revise your guide to include this: "Two extensions are required. Even if the second extension is a 'dummy' account"
    Thank you
  4. YiannisH_3CX
    May 10, 2016
    4,404
    282
    Glad to hear this worked. This is actually a bug that it has been addressed for SP5 which is currently on beta testing.
  5. Michael Menor
    Dec 30, 2016
    37
    @YiannisH_3CX After being provisioned, what is the username and password for the ATA172 changed to? I'm not able to log into the ATA with the default credentials: root / test
  6. YiannisH_3CX
    May 10, 2016
    4,404
    282
    In SP4 we don not provision a password for FXS/DECT devices so it should still be the default. Unless you downloaded the templates intended for SP5 (in sp5 passwords will be provisioned for FXS/DECT devices). In that case the password should be %%DEVICE_PASSWORD%%
    as there is no password set in the management console for the template to replace the value with. Try it and provide us with a feedback
