Solved Welltech ATA172 plus provisioning problems
Discussion in '3CX Phone System - General' started by Fred Vierra, Dec 7, 2017.
  1. Fred Vierra
    Nov 20, 2017
    13
    I have a 3CX Server running on debian and I am currently having issues getting this Welltech to provision. I followed the steps in the configuration web page and also saw that both extensions had to be setup so I did that as well.
    I factory reset it, loaded the firmware, and then auto provisioned. It restarts but then doesn't let me log back into the webpage with 3CX device Web Page Password or the factory "test" password.
    I tried locating the file .dat to check it out on the 3CX server via ssh but to no avail so I loaded the .dat file into the /provisioning/xxxx/ directory and that didn't change anything either.
    Any suggestions?
    Thanks,
    Freddie
  2. Fred Vierra
    Nov 20, 2017
    13
    I got it figured out. Looks like 3CX blacklisted the IP's. Don't know why I didn't look back on the logs earlier.
  3. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    Hi Fred Vierra,
    Glad to hear you found a solution. The IP's probably got blacklisted for exceeding the number of Failed Authentication attempts.
