Welltech ATA172plus
Discussion in '3CX Phone System - General' started by neville, Jul 15, 2016.
  1. neville
    neville New Member
    Apr 23, 2012
    222
    39
    How do I add the Welltech ATA172plus? I have ran updates for it, but it is not found when trying to select it under gateways for Welltech.
  2. Aram
    Aram Support Team
    May 7, 2012
    154
    30
    Hi neville,
    The ATA (FXS) devices are not added yet. We will add them soon.
    For now you can add and register them manually:
    1. Open the Management Console and navigate to the FXS/DECT page;
    2. Add 2 extensions there and save the usernames and passwords in the text file;
    3. Download attached file and rename it from MAC.txt->to MAC address of your ATA172 device .dat (all letters capital). Example: 0001A80A2F73.dat ;
    4. Edit the file and make the following modifications:
    PBXIP - change to the IP address of your 3CX Phone System
    PBXSIPPORT - change to the SIP port of your 3CX Phone System (default is 5060)
    EXTNUMBER1 - change to the number of the first extension
    EXTPASS1 - change to the password of the first extension
    EXTNUMBER2 - change to the number of the second extension
    EXTPASS2 - change to the password of the second extension
    5. Save changes and paste the file into the "C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\SECURE_FOLDER" folder.
    6. Do the Step 2 of the following guide:
    http://www.3cx.com/voip-gateways/wellte ... ta172plus/
    Sorry for inconveniences - ATA (FXS) will added soon.
    • MAC.txt
      File size:
      6.8 KB
      73
