what constitutes a simultaneous call?
Discussion in '3CX Phone System - General' started by smokeman, Apr 22, 2011.
  1. smokeman
    Dec 10, 2010
    50
    just wondering if 1 extension calls a second extension, is that 1 call, or 2?
    also, is an extension that calls out, over a voip trunk connection, 1 call, or 2(1 connection from phone to pbx, another from pbx to voip channel)?
    just trying to get licensing figured out.
    Thanks,
    Barry Smoke
    AR Division of Legislative Audit
  2. smb1
    smb1 New Member
    Mar 18, 2009
    104
    Both cases should be considered a single call.
    To confirm what 3CX thinks is going on is to to check the system log during a call to see the concurrent calls that are taking place.
  3. leejor
    10,781
    286
    A voice path (conversation) between two parties(internal or external) is a call. This holds true in most cases. As I understand it, transfers, calls in queues, and three-way calls may be counted as an additional call.
  4. smb1
    smb1 New Member
    Mar 18, 2009
    104
    Do connections via a bridge consume another call? I have a recollection of this being the case in earlier versions.
  5. leejor
    10,781
    286
    Why would they not? A bridge call is a call between two parties. No different than placing an outside call on any trunk.
  6. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    When incoming call from siptrunk rings 5 extension is this 1 or 5 calls?
  7. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    The question regarding the ring group......
    It is one call.
    When the system answered the incoming, it did so using the system extension for the ring group. That extension still "held" onto the call while the system rang the phones associated to the ring group. When one of the extensions answers, the call is then transferred to that phone, so it still remains as one call.
  8. jholcombe
    Jul 9, 2014
    79
    I believe that paging (one handset paging out to multiple handsets) also counts as one call.
  9. leejor
    10,781
    286
    In the case of paging and ring groups...the call has not yet been terminated, station to station. If you had a 4 SC licence and attempted to page 8 extensions, you'd continually run into problems, correct?
  10. humansys
    Oct 28, 2015
    11
    I'd also like further clarification. In the demo test when I tried to make an inbound call and the inbound call hit a ring group, and my extension is setup to simultaneously ring my cell phone and desk phone, I was told I was out of licenses of the free version, so it appears ringing a cell phone takes up another simulataneous call. Does this mean each additional find me/follow me adds another simultaneous call? If this is the case it really significantly increases the licensing costs for most cloud companies. For a two-person office they'd need the 4-seat license, and a 3 person office would need the 8-seat license (one inbound call would mean one inbound, one ring group, and 3 cell phone "licenses").
  11. leejor
    10,781
    286
    A "ring my mobile at the same time", outgoing call, is considered a second call (until one end is answered), as I've experienced myself.
    Your scenarios rely on all extensions receiving calls at the same time. So...looking at that another way...if you have an office with, say, four extensions (all with the ring my mobile option), and four outside trunks, if all four of the extensions were receiving calls at the same time (or two placing calls and two incoming), you'd have no outbound trunks to also send the calls to mobiles, you'd need twice as many trunks as you had extensions if everyone had this option, just to guarantee no blocking. It all depends on how far you are willing to go, how much you are wiling to spend, to cover a worse case scenario.
  12. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Even if we use 3CX app?
  13. lneblett
    Sep 7, 2010
    2,083
    61
    The app is an extension and treated as such, no different than if you had a remote extension. The mobile (cell) aspect is an independent device that is not attached to the system natively with a registration like the app, but requires the use of an outside number that then uses the carrier's cellular signal (TDMA, GSM, CDMA, etc.) to reach the device...another call
