What directory permissions are required?
Discussion in '3CX Phone System - General' started by FGCUHank, Mar 1, 2010.
  1. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    I'm using IIS and suspect that I need to update some directory permissions.
    For provisioning I had to enable access to the provisioning folder in all users\application data\3cx\data\http\interface
    When trying to restart the SIP/RTP Tunneling proxy I get an "An Exception occured Restart Service Error: Cannot open 3cxtunnel service on the computer" But I can from services.msc.
    Also I am unable to change the default password and port for the tunnel. Just mention this in case it is related.
    Thanks for any feedeback.
    Hank
