What Do I Need To Purchase
Discussion in '3CX Phone System - General' started by SirBill, Apr 16, 2007.
  1. SirBill
    Apr 16, 2007
    9
    What do I need to purchase to connect vonage Dlink ATA to the 3cx? I would like to use the existing vonage lines. My apologies for the elimentry question.
    SirBill
  2. SirBill
    Apr 16, 2007
    9
    I found the answer by using the search. I thought that question would have been asked before. DUH.
    P.S. I really like the phone system.
  3. Anonymous
    Anonymous Guest
    Your ATA connects to your network via a router/switch if it does not have that capability by it self.
    Your 3cx computer attaches to that same router/switch and you are up and running.
    Anyway a picture tells a thousand words
    http://www.3cx.com/phone-system/product-tour.html
    Let us know what is not understood.
  4. SirBill
    Apr 16, 2007
    9
    I was hoping to be able to control the Vonage ATA by making the 3CX think it was a phone line. I thought maybe a gateway or something. Looks like I have to purchase a Vonage softphone line or change to a different provider. BroadVoice seems to provide the same service with a lot more flexability.
