What does 'allow barge in' do in a voice design?
Discussion in 'CRM / Helpdesk / App Integration' started by markv, Oct 9, 2012.
  1. markv
    Sep 17, 2012
    9
    The help says 'True to allow the prompts to be barged into. False otherwise'. This is not the kind of usefull help... I still don't know what is meant by 'barge' and what's the effect, other than a prompt is allowed to barge in...
    Greets,
    Mark.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi Mark,
    The Allow Barge In property specifies if prompts can be interrupted by DTMF or not. If that property is set to true, then the message can be interrupted by a following user input request. If the property is set to false, the message will be played complete, no matter if the user presses a DTMF key or not.
    For example, if you have an important notification for your users and you need that they hear it, then you set the property to false, and the message will be played entirely.
    It is a good practice to set that property to false if this is the last message to play before transferring or disconnecting a call. Take a look at this blog article:
    http://www.3cx.com/blog/docs/config-last-message-to-play-on-a-vad-app/
    Regards,
  3. markv
    Sep 17, 2012
    9
    Hi, this is great help, 3cx should apply this text in their help. Tnx a lot!
    Greets,
    Mark.
