What does "PBX Delivers Audio" mean?
Discussion in '3CX Phone System - General' started by coreybrett, Feb 7, 2011.
  1. coreybrett
    Apr 12, 2010
    72
    What exactly does "PBX Delivers Audio" do?
    11,116
    329
    It forces the voice packets to go back to the 3Cx PBX rather than go directly between two SIP devices, once a connection is established. Depending on what two devices are being connected, it may not be possible, to have the connection set up any other way but the audio passing through 3CX.
