What is 3CX PhoneSystem default login?
Discussion in '3CX Phone System - General' started by rthee, Jun 1, 2010.
  1. rthee
    Feb 9, 2010
    6
    Hi there,
    I have just upgrade 3CX Phone System from v7.1 to v8. During the final installation, I have restored the backup from v7.1 and tend to adjust previous configuration at Manage Console page, however, I couldn't login with the previous default details: admin/monday1.
    Any ideas? Kindly appreciated with your help. Many thanks!
    Ryan
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    The password username should remain unchanged.
    Please generate support backup from the Backup and restore tool by doing the following:
    Start > Programs > 3CX Phonesystem > 3CX Backup > Generate Support info.
    Send that file to lg@3cx.com and i'll PM you your password.
  3. KenC
    Mar 29, 2012
    85
    I've got v. 10. Backup/Restore doesn't seem to have an option for generating support info.
    Thanks!
  4. KenC
    Mar 29, 2012
    85
    Figured out how to generate support info.
  5. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    look the attach, first press "Browse" and puth the path where the support file will be placed, then generate support
  6. KenC
    Mar 29, 2012
    85
    Where in the support info zipfile can I find my username and password for the windows management console?
    thanks
  7. leejor
    10,375
    231
    I seem to recall that this question came up, and was answered not that long ago in the forum. If you do a search through the zip file, for what you think it should be, or at least part of it, you should come across it.
