What is a "RECORDING"
Discussion in '3CX Phone System - General' started by petewatterschats, Mar 25, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    Extensions - 3CX Client
    There is a check box for "Show Call Recordings", they do not appear to ve voice mail or Greeting recordings so what are they
    I use the client to show them but I have none, i did make greeting wav files for this extension and I did have a voice mail for this extension
    11,291
    361
    These are recording of conversations, when the PBX is set to do so.
  3. petewatterschats
    Jan 19, 2016
    151
    Thanks, I understand now
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    or when someone hits the "RECORD" button during a conversation.
    ...and listing of said recordings can be found in the soft clients...
    If I understand correctly, links to the recording are also found in the Call Logs.
  5. petewatterschats
    Jan 19, 2016
    151
    I looked for a record button on the windows client but can not see one
    If I leave unchecked the record all calls in extension setup
    How can I record at my option a call on the windows client and on a Hard Phone
  6. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,387
    88
    Below I took some screenshots of what I had available.
    3CX Phone has a "Rec" button when you are on an active call.
    For deskphones, some of them allow you to set a "Record" button from their interface which, in most cases, works exactly like the "Rec" button on the 3CXPhone app, however this option will have to be set in the interface manually, it cannot be done through the Management Console.
    Not all phones have these options though. Also note that this option has not been tested by the 3CX R&D department, but for the below 2 models, at the time of writing this it works.
    3CXPhone:
    [​IMG]
    Yealink T46 (fw v28.73.0.50):
    [​IMG]
    snom 870 (fw v8.7.5.35):
    [​IMG]
  7. petewatterschats
    Jan 19, 2016
    151
    I am testing on a Yealink T21PE2
    Line Key 1 and Line Key 2
    If I setup Line Key 1 to record, does this mean that all calls will be recoreded or is there a way to toggle on and off
    I get the impression that selective recording on hard phones is not a common practice - is this correct
    Programable Key and a set of keys under this, I think I should leave these alone
