What is Call Que? Ring Que
Discussion in '3CX Phone System - General' started by miraportuga, Jan 21, 2008.
  1. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    about call queue, everything you said its correct, so your thought is correct.
    About diferences on the editions, the diference to the enterprise edition is the same has professional o Small Business, you just have even more lines(able to use G729 on more lines has well) and extensions then you can in the pro version.
    Cheers
