1 ) Uninstall 3CX server
2 ) Uninstall 3CX client
3 ) Delete the folder 3cx
4 ) regClean 3cx
5 ) Factory default HT488
6 ) Restart Winxp
Then:
1) install 3cx server
2) Add extantion
3) Restart WinXP
4) Add PSTN HT488
5) Restart Winxp
6) Login HT488 enter the IP, user ....
7 ) NAT on the router
8 ) Edit STUN server on X-lite <stun.3cx.com>
udp 5060 192.168.2.21
tcp 5090 192.168.2.21
tcp 5080 192.168.2.21
tcp / udp 3478 192.168.2.21
tcp 5481 192.168.2.21
udp 9000-9007 192.168.2.21
udp 10000-20000 192.168.2.21
8) install X-Lite YEA it is ok. But i have got problem 3cx-Client ver.6 wenn i install my icon on the right site on the Monitor --DE-- change the color.
Next problem, i can´t call automaticly, i have outbound rule #.
X-Lite or 3Cx-Client or ATA286 it is the same problem. Wenn i calling #123456, call dail tone is ok, but i don´t hear any DTMF or call forwarding, i must type again the number 12345 than i hear DTMF. Sametimes the number ist true, sametimes the number is false? (Greandstream HT488?)
I call with ATA268 #PP0P17648132327 P=pause
FXO Setting HT488 :
If current disconnect enable, use thredshold: Default was 100ms change it 8000ms :lol: :lol: :lol: :lol: :lol:
YEA i have got it!
