What mean this log message? MediaServerReporting::STUN
Discussion in '3CX Phone System - General' started by jrme1, Aug 22, 2007.
  1. jrme1
    Jun 14, 2007
    26
    Hi, since i upgrade to Version3.1.2434.0 i receive sometimes this message in my log:
    [MS101003] Call(22) Sip:025131203@10.0.0.1: Possible firewall problem. Address mapping failed on STUN server 194.221.62.209:5060 for local address ":9048"
    [MS101003] Call(9) Ext.10006: Possible firewall problem. Address mapping failed on STUN server 80.239.235.209:5060 for local address ":9022"
    Sometime dialing internal and other dialing external. The call is maded normally, but what is that??
    I using the 3CX stun server.
