What mini PC was in the video
Discussion in '3CX Phone System - General' started by ucs1, Jul 7, 2016.
  1. ucs1
    Jun 21, 2013
    42
  2. peterke
    Jul 7, 2016
    will this atom based pc do for running a 3CX pabx for 5-10 users and 2 simultaneous calls?
    Requerements seem to be an i3 processor.
  3. ucs1
    Jun 21, 2013
    42
    In the Live Stream I believe they said up to 32SC systems (You may want to replay the Live Stream to verify for yourself, I have set it to start from the relevant section for you)
    There has only been reference to using this with v15 and I couldn't comment on v14 as the architecture has changed for v15 which reduces overheads. I believe there were going to be some test results posted in the coming days.
  4. andreaschr
    andreaschr Support Team
    Oct 26, 2015
    93
    6
    Hi all
    You need to ensure that it will come with 64bit windows .
  5. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    It was also mentioned to prefer a 4GB RAM version.
  6. AlexanderHanna
    Oct 2, 2015
    79
    10
    Hi, would a device like this with 2GB be recommended for and SBC?
    Thanks,
    Alexander
  7. accentlogic
    accentlogic New Member
    Nov 14, 2013
    161
    66
    I purchased one of the Wintel Pro devices, https://www.amazon.com/gp/product/B01DW1Z07Q/
    It seems to work great, but there is one major issue - it does not power on after power loss. There is no setting in the BIOS to make it do so. Almost a deal breaker for me. Yes, you always want a UPS, but then when the battery dies you still have the issue. The VENSMILE with the built in battery is interesting, I will look at that, especially for use as an SBC in cloud deployments.
    As to the RAM and CPU requirements - Based on what has been stated by 3CX I think v15 has significantly lower requirements.
    If anyone finds a Windows 10 appliance that can be set to power ON after a power loss please let us know.
  8. leejor
    10,362
    227
    Regarding Windows 10 (as supplied with these machines), it is my understanding is that unless you are running the Enterprise Edition, updates will be downloaded and applied automatically. One reason I've avoided it altogether.
  9. neville
    neville New Member
    Apr 23, 2012
    202
    33
    I'm using the NexBox for both V15 SBC and V15 3CX for testing purposes. So far, both have worked very well. Voice quality seems to be much better on the V15 SBC to V15 3CX as opposed to the V14 SBS to V14 3CX.
    The one I use has 4G Ram and 64G disk. It is the one that evowire post above.
