What Virusscan can run with Win Server 2003 & 3CX
Discussion in '3CX Phone System - General' started by landfiets, Jul 24, 2007.
  1. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    In my first try I used NOD32 virusscanning software but it changed the whole Windows Server 2003 setup and I couldnt reach my 3CX PBX anymore
    Does anyone know what virusscanning software is running smoothly on Windows Server 2003 and giving no problems with 3CX?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    We are using McAfee VirusScan Enterprise v8.5.0i. It works fine.
    If in need to use external SMTP server for voice mail to email. You must Untick "Prevent mass mailing worms from sending mail" or set it allow 3CX to use mass mailing.
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I really like Trend Micro OfficeScan for servers. Never had any program conflict issues unlike McAfee or Symantec.
  4. Anonymous
    Anonymous Guest
    All virus scanners will work from my experienc, it is the port blocking and file locking that suffs it up.
    If you configure it right you should have no troubles with any virus scanner software.
  5. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    While this is very true, I've had lots of problems with software not working because of Symantec being a resource hog or doing too much on the files as it's being checked.
  6. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Symantec Anti-Virus program bug crashed over 10,000 PC's Windows OS at China for around 1 month ago... :( :(
  7. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    No one beats their marketing though!
  8. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    I like to exclude temporary files or text only files like .log in Symnatec antivirus. What temp files extensions does the pbx use during the queueing and execution of the calls?
  9. woodduck
    Jun 15, 2007
    6
    Symantec
    I know its expensive, but you can't beat Symantec Corporate Antivirus. You can also license it for your client machines, and have it centrally managed by the server.
  10. hcv
    hcv
    Jul 30, 2007
    5
    NOD32 beats Symnatec.
    NOD32 is a very good choice.
    Have you installed IMON on the Windows 2003 server?
    NOD32 advices to use IMON on desktops and notebooks and not on servers.
    Scanning for traffic on ports 80, 8080 etc.. only makes you server slower.
    And might causes problems.
    Even with the fastest virus scanner on the market.
    Do you like to compare virus scanners?
    Go to http://www.shiftingviews.nl/vragen/v00036.html for a link to AV-Comparatives that shows what virus scanner is the best.
  11. Fynskisb16
    Jul 18, 2007
    21
    I'm also using Symantec Antivirus CE 10.1.5.5000 on my server and no issues.
