What VOIP provider are you using - poll
Discussion in '3CX Phone System - General' started by Nick Galea, Apr 6, 2007.
What VOIP provider are you using?
Poll closed Jul 5, 2007.
  1. VOIPbuster
    0 vote(s)
    0.0%
  2. Vonage
    0 vote(s)
    0.0%
  3. BroadVoice
    0 vote(s)
    0.0%
  4. Sipgate
    0 vote(s)
    0.0%
  5. Nikotel
    0 vote(s)
    0.0%
  6. Other provider (working - post URL)
    0 vote(s)
    0.0%
  7. Other provider (not working - let us know)
    0 vote(s)
    0.0%
  1. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,915
    221
    Let us know the most popular providers out there. Let us know which ones you feel need to be supported as well... And let us know which providers are working just fine so we can add them to the supported list!
    Thanks for your cooperation.
  2. mbs1
    Mar 7, 2007
    35
    i have sucessfully used http://www.voipcheap.co.uk and http://www.voipcheap.com.
    fwd ( http://www.fwdpulver.com) also works but i am not able to use * in the dialling string to call peers
    thanks
    mbs
  3. Anonymous
    Anonymous Guest
    Using Internode for a while now, their VoIP service is:
    http://www.internode.on.net/nodephone/
    This is an Australian based service provider.
    Henk.
  4. wewake
    Apr 5, 2007
    10
    Sipgate works real good for me
  5. palsbo
    Mar 31, 2007
    10
    musimi.dk
    musimi.dk works fine
  6. costellazione
    Mar 31, 2007
    8
    WWW.ITALIADSL.IT
    http://WWW.ITALIADSL.IT is a good cheap Italian VOIP / ADSL Provider.
    They supply guaranted bandwidth and geographic voip numbers.
    I have sucessfully used its voip service in combination with 3cx Pbx.
    Everything worked fine at first configuration.
  7. dekatech
    Feb 13, 2007
    82
    Junction networks
    Allows a great deal of flexibility in conguration and allows for reselling of numbers. US
  8. netmatika
    Feb 16, 2007
    17
    Sip Providers Work!
    Hi all,
    i've tried Skypho and Voxalot sip Provider and they work very well on 3CX!
    Skypho
    Outbound Proxy Hostname or IP voip.eutelia.it
    STUN stun.voip.eutelia.it
    ID xxxxxxxxxxx (ID Telephone number)
    Voxalot(for european users)
    Outbound Proxy Hostname or IP eu.voxalot.com
    STUN eu.voxalot.com
    ID xxxxx (ID Telephone Number)
    Thanks to 3CX
    Netmatika
  9. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    VoIP.com
    VoIP.com if fairly tight lipped about their settings due to some abuse on their system. Here is some info from one of their files.
    SIP_Proxy:voip.freester.com
    Local IP:0.0.0.0
    Local Port:5060
    Proxy Host:sd.voip.freester.com
    Proxy Port:5060
    Stun Host:
    Stun Port:3478
    If this helps anyone let me know so I can try to get my Equip. to work with it.
    Cjammer
  10. NigelG
    Mar 29, 2007
    48
    VOIP
    Sipgate, it works a treat with 3CX
  11. skovoroda
    Apr 14, 2007
    Wengo
    Wengo (www.wengophone.com) of France works.
    Outbound Proxy Hostname or IP voip.wengo.fr (do NOT use the IP address)
    STUN server stun.wengo.fr
  12. Tugi2o
    Feb 20, 2007
    61
    http://www.3cx.com/forums/viewtopic.php?t=1221
    NOT WORKING
    i am using ARCOR [GER]:
    there is still one problem:
    when i call s.o. his phone is ringing. if he doesn't respond, i hang up, but his phone is going on ringing => http://www.3cx.com/forums/viewtopic.php?t=1221
    If i use 3cx phone directly connected with my VoIP provider (without 3cx phone system), there is no problem, the called phone stops ringing when i hang up.
    i have tried other phone system software and they all provide Arcor without this error. also other phone software like x-lite etc. provide Arcor.
    so i hope that 3cx phone system software will provide it too :)
  13. no1daag
    Feb 8, 2007
    29
    I
  14. Mori
    Mori New Member
    Mar 23, 2007
    223
    Norwegian users
    Partially working.
    http://www.ip24.no (Norwegian users)
    Only problem i have is DTMF not beeing transmitted correctly on incomming calls, and the result is that digital receptionist not handeling calls as requested. :(
    Otherwise it works fine...
  15. ksantella
    Apr 23, 2007
    23
    I have configured the following without issue:
    voipbuster
    teliax
    junction networks
    I use outbound dial rules to choose i.e regular dialing, 1+number is voipbuster, 2+ number (with the "r" to strip the 2) is teliax, 3 for junction.
    k
  16. garambula
    Apr 2, 2007
    9
    I use ViaTalk works great. http://www.viatalk.com
  17. bgrubbs
    May 15, 2007
    SIPphone.com
    I configured SIPphone.com without any problems.
    http://www.sipphone.com/
    or
    http://www.gizmoproject.com/ (same thing)
    - Bill
  18. Jim
    Jim
    May 24, 2007
    DigiSIP
    http://www.digisip.se
    Does NOT work because they require different SIP ID and AUTH IDs. :(
  19. henlon
    Jan 3, 2007
    8
    cellip
    Cellip AB in sweden own's mysercretary.net
    I have tried several times to get 3cx work together with cellip.
    The problem is to answer incomming calls. 3cx can't receive calls.
    The provider works fine on stanalone sip phones
  20. pkothe
    Feb 2, 2007
    39
    Quality Voice Provider
    http://www.voicestep.com seems to be geared toward your business clients and from the demo line I have been using they are very good quality. I also have a broadvoice line and it works pretty good also but I think the Voicestep line has an edge on quality.
