What's better? AudioCodes MP-118 or 2 Patton SN-4114?
Discussion in '3CX Phone System - General' started by RobLloyd, Apr 2, 2008.
  1. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I have a client switching back to PSTN after some issues with voip and their ISP. They are getting 7 lines.
    What would be better, price no object, for 7 PSTN lines? Not terribly happy with the Grandsteam devices so that leaves Audiocodes MP-118 (or 2 MP-114) or 2 Patton SN-4114.
    Thanks,
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    I prefer Patton SN-4114 than Audiocodes MP-118.
    My concern is the technical matter. Since support at 3CX side, Patton should be stronger than Audiocodes.
    On the other hand, Audiocodes also the good gateway. Caller ID decode should be stronger than Patton's FXO gateway. However, Audiocodes' GUI changed long long ago, the support page of 3CX still post the very old version's instruction. Most of setting at that gateway had been changed.
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Thanks for the reply Ricky - I have used the MP-114 at another clients with pretty good luck and I did notice the instructions are different than what 3CX has but I worked it out.
    You seem 50/50 on which one to pick? I haven't used Patton yet so I'm not sure which has better audio.
    Can 3CX handle 8 lines over a 10/100 network?
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,971
    280
    Patton, i'd say. Nothing wrong with the Audiocodes, however we just get better support from Patton. That said if you have a supplier that can really support the audiocodes you can give it a shot.
