What's SIP header for "auto-answer"?
Discussion in '3CX Phone System - General' started by crtg08, Jun 11, 2013.
  1. crtg08
    Jun 11, 2013
    What's is SIP Header for 3CX auto answer feature?
    Thanks..
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Header?
    I ran a WireShark on an inbound call on a test PBX and test trunk with 3CXPhone set to Auto-Ans.. there appears nothing out of the ordinary.
    The capture shows 180 Ringing followed by a 200 OK a fraction after that, from my phone to the PBX, with SDP to set up the streams on the 200.
  3. crtg08
    Jun 11, 2013
    Normally I am using this header "SIPAddHeader(Call-Info:\;Answer-After=0)" for grandstream. But I couldn't find for 3CX.
    Have you used like this header before?
  4. crtg08
    Jun 11, 2013
  5. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    I am not aware of a Sip request/response for an auto-answer. the far end device is usually set for AA and does so when it sees a ringing request. If the far end device is not set to AA, i am not aware of a way of making it auto answer (unless it is set to allow page/intercom, which is a different setting altogether).
