What's the difference between free version and Demo?
Discussion in '3CX Phone System - General' started by cd123, Apr 2, 2014.
  1. cd123
    Jul 22, 2013
    5
    Currently, I'm using the 3CXPSDEMO, which shows "Number of Simultaneous Calls" is 2. I tried to call 3 numbers with 3 extensions at the same time, and it was working. Is there any difference between free version and Demo? The free version has 4 simultaneous calls.
  2. carolinainnovative
    May 4, 2009
    369
    5
    The demo license allows you to try the commercial features but limits you to two simultaneous calls. Or... is supposed to. If it gives you more than two, then it is your lucky day.
    Comparison between the editions - see page 7/8 in this brochure:
    http://www.3cx.com/phone-system/3CXPhoneSystem_brochure.pdf
    an older version is here, and is still mostly correct (with the exception of simul calls)
    http://www.3cx.com/phone-system/edition-comparison/
  3. VoIP2Go
    Apr 8, 2014
    I am looking at learning 3cx from an old copy I have of 3CXPhoneSystem11.exe and have a few questions:
    Is there a newer free version?
    Is it within the licensing requirements to install the free version at more than 1 location?
    Can the free version be used commercially?
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    The free version can be used in anyway you like wether for test purposes or commercially. Due note you are limited to two concurrent calls that includes internal calls. So if you get any kind of call volume than the free version will not work due to the 2cc limit..
