what's type of DTMF should I used in IP-Phone
Discussion in '3CX Phone System - General' started by lotsu99, Dec 23, 2008.
  1. lotsu99
    Jan 1, 2008
    27
    what's type of DTMF should I used in IP-Phone ?
    Inband or Outband ?? Thx
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    It would be best to use RFC2833 for DTMF. It is the most reliable.
  3. Powermage
    Powermage New Member
    Mar 19, 2008
    103
    The most important thing is what your voip provider support's,
    the problem is that when you dont have a provider that isnt using the RFC DTMF you will have problems when 3cx is delivering audio (by default on you voip line)
