When adding DID number 22
Discussion in '3CX Phone System - General' started by mikebuzz, Oct 24, 2008.
  1. mikebuzz
    Mar 19, 2008
    Seems that i can only add 21 DID numbers to the incoming provider, any idea how to resolve this error
    Internal server error
    Cannot save Provider object: ERROR: value too long for type character varying(255)<br>#0 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fGateway.php(289): safeExec(Object(PDOStatement), 'Cannot save Pro...')<br />
    #1 C:\Program Files\3CX PhoneSystem\Data\Http\gateway_lines_upd.php(405): fGateway::save(Object(oGateway))<br />
    #2 {main}
  2. mickp
    Jun 9, 2008
    72
    Hey there,
    I noticed this on our trunk configuration. It appears to be a problem with teh form. I eventually worked out that the setting is not necessary. Everything is working fine without having the did numbers listed here so I'm not sure what the setting is meant to do.
    Perhaps someone else could clarify this.
    See http://www.3cx.com/forums/working-voip-providers-5011-45.html#p37919 for details on how I have things configured. The did's are created elsewhere and work fine.
    Mick.
