When I call someone they cant hear me
Discussion in 'Windows' started by Jiggr, Sep 6, 2010.
  1. Jiggr
    Sep 6, 2010
    I have used a lot of SoftPhones but this one seems to be really good. But I have a problem and I hope someone can help me.
    When I call someone they cant here me but I hear them. But if they call my phone we will hear each other. I thought it was some kind of problem with my firewall but I have tested it on different computers with the same result.
    I have two phone operators i can choose from. And it is only with one of these phone oprerators I have the problem. How is that possible?
    Thanks in advance!
  2. dag
    dag
    Nov 13, 2010
    I have the same problem.
    Uses Windows XP SP3, connected directly to internet without any router, firewall or antivirus.
    Tried with another PC - same problem.
    Tried another softphone - no problem.
    Hope there is any solution because this phone seems nice.
  3. leejor
    11,116
    329
    Which provider doesn't work? Which one works? Are you behind a router? Which make/model? Are you using STUN? Have you tried using Wireshark, to compare the two calls? What does the 3CX phone log (Debug) show on each call?
  4. Gregplummer
    Nov 26, 2010
    When I call someone they cant here me but I hear them. same problem
