When I move a phone on the same network I get a no service
Discussion in '3CX Phone System - General' started by Philip Swift, Jul 21, 2017.
  1. Philip Swift
    Jul 21, 2017
    I went to move a phone onto a switch on the same network and as soon as I did, it had no service. Even when I plugged it back into the same port it was in there is still no service.
  2. giwm
    giwm New Member
    Sep 27, 2016
    217
    36
    Are you sure the ports are configured for the same VLAN?
  3. Philip Swift
    Jul 21, 2017
    They are. There in only one VLAN
  4. Philip Swift
    Jul 21, 2017
    And it was on the same port, just moved to a switch off the same original line.
  5. leejor
    10,360
    226
    In the 3CX Activity log, do you see a registration attempt just after the set is plugged in? Could it be attempting to re-provision itself, and failing?
