when will the next edition release?
Discussion in '3CX Phone System - General' started by rewing, Sep 26, 2007.
  1. rewing
    Sep 1, 2007
    25
    I guess next edition it will integrate T38 support, which can make an extension as a fax machine.
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Yes for T38. According to some threads I have read, v4 will probably be about mid-October. Don't hold me to it though, I am not on 3CX payroll :lol:
  3. Anonymous
    Anonymous Guest
    Ok I do not want to be the party pooper, but I do not think the fax machine will be seen as an extension. (could be wrong) it might be a bit less sophisticated than that.
    EG receive fax as PDF
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Very good news for V4 can support T.38
