Where a WorkFlow could be placed
Discussion in 'CRM / Helpdesk / App Integration' started by edoardo.panzeri, Jan 23, 2012.
  1. edoardo.panzeri
    Jan 20, 2012
    Hallo,
    i'am starting a project using VAD environment;
    i am asking you where a WorkFlow could be connected: only to a IVR (activation extension) or also when an event has emerged (for example: 'out of office' status, ....)
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    A VAD callflow is registered as a special digital receptionist. Then you can trigger it whenever you need, for example into a standard IVR or as a forwarding rule for an extension.
    Regards,
