Where are recorded calls?
Discussion in '3CX Phone System - General' started by thames, Feb 22, 2013.
  1. thames
    thames New Member
    Apr 4, 2011
    108
    Hi Folks
    Could someone let me know where the actual recording of a call is located on the disk? I've set one of our extensions to record all calls (V10) but cannot find the resultant .wav file?
    Cheers
    Chris
  2. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    did you lock here:
    C:\Documents and Settings\All Users\Application Data\3CX\Data\Recordings
  3. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    Go to your Management Console then go to settings, click on General Settings and then select Global Options. Once there you will see the recording Path. Change that to wherever you want to save the recordings maybe for easier access, otherwise the default path will be listed there.
  4. black6
    Nov 26, 2012
    9
    You can also view recorded calls within MyPhone subject to permissions assigned by the administrator. This also allows you to delete, listen over phone, or play on PC, again subject to permissions granted. I think I am correct in saying that all recordings have to be stored on a local disk and cannot be mapped to external sources.
    Hope this helps.
    Regards,
