Where are the activity logs
Discussion in '3CX Phone System - General' started by oliverm, Sep 6, 2011.
  1. oliverm
    Mar 10, 2009
    79
    Hi chaps,
    Anyone know where 3cx keeps the server activity logs? Clearly it shows a small sample in the admin app but I want to look at the logs going back for several weeks to look at an issue, but I can't see anything in 3cx that details the location of them only the logging level,.
    Any ideas?
    Olly
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Windows 2008 or Windows 7 the logs are at
    C:\ProgramData\3CX\Data\Logs
  3. oliverm
    Mar 10, 2009
    79
    Is it possible to change that? I'd like to move them to a seperate partition with more space.
  4. willow
    willow Member
    Mar 1, 2011
    471
    3cx should be installed on the new partition then.
