where are the fax received ?
Discussion in '3CX Phone System - General' started by CBSYSTEM, Aug 5, 2010.
  1. CBSYSTEM
    Dec 14, 2009
    11
    I have a 3CX V9 and a beronet card that I need to use to receive the fax but I have no internet connection on PC so no way to send an email with fax attached, so where can the users go to see the fax received ?
    If anyone knows...
    thank you
    Cyril
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hello,
    see here C:\Documents and Settings\All Users\Application Data\3CX\Data\Fax\
