Where are the WAV files for Voice Prompts ?
Discussion in '3CX Phone System - General' started by cfjacques, Nov 18, 2010.
  1. cfjacques
    Nov 9, 2010
    HI there, I am trying to translate the WAV files to my idiom, but, I searched all the hard driver to see where are the WAV files for the voices, but there is no WAV files into the installed 3CX...any ideas ? I search the forum and I found some users informing the files folders, but into my instalation I dont have such folders. I am using Version 9 SP4 9.14901.
    Thanks,
    Cristiano
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Depending on your OS they will either be in the Program Data or All Users Application Data. Both of these folders are hidden by default on windows. So go into windows folder options and show hidden files and folders.
