Where can I find an SP2 ISO?
Discussion in '3CX Phone System - General' started by jimbo59, Feb 15, 2018.
  1. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    I want to downgrade. Does 3CX have a page with old versions?
    Please put the link.
  2. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    @NickD_3CX:
    Then you can run: apt-cache policy 3cxpbx This will return a list of all the versions of that package that are available online in the repository.
  3. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    So once it do apt-get remove 3cxpbx* and autoclean and I want to do apt-get install 3cxpbx=15.5.6354.2, right?
  4. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Yes. @jvivona would also recommend apt-mark hold 3cxpbx
  5. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    You should be able to afford paying maintenance or renewing annual license, so use the latest SP3 instead. It has more features and is performing better. Also you can't restore a newer backup to older 3CX version, even you have found the image.
    #5 sip.bg, Feb 15, 2018
  6. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    @3CXfoxhallsolutions:
    To be sure - you would need to restore your configuration from an earlier back-up which was made under the 3CX version that you are downgrading to ...
