Where can I find the log files for the Call History Service?
Discussion in '3CX Phone System - General' started by coreybrett, Jun 25, 2012.
  1. coreybrett
    Apr 12, 2010
    72
    I am trying to determine why that service keeps stopping on me. Also, after a server reboot, it fails to start and I have to manually start it.
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Re: Where can I find the log files for the Call History Serv
    Usually they can be found in this location : C:\ProgramData\3CX\Data\Logs
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Open up the 3cx folder under programs you will see call history log. You can then move it to the start list if you choose.
