where did that go!!!
Discussion in '3CX Phone System - General' started by spec, Feb 22, 2008.
  1. spec
    Sep 8, 2006
    51
    clicked on backup database but cant find where it saved to
    thanks
  2. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    If you click backup again just look where it defaults to then cancel the backup, you will the know where the original backup was saved.
    Stephen
  3. spec
    Sep 8, 2006
    51
    tried that.. click on it then this pops up in lower window
    Saving Database.
    saving table dn. 8 row(s)
    saving table specialmenu. 1 row(s)
    saving table faxextension. 1 row(s)
    saving table parkextension. 0 row(s)
    saving table extension. 2 row(s)
    saving table extensionforward. 8 row(s)
    saving table users. 2 row(s)
    saving table voicemail. 2 row(s)
    saving table gateway. 3 row(s)
    saving table iprange2gateway. 0 row(s)
    saving table provider. 3 row(s)
    saving table codec2gateway. 9 row(s)
    saving table inboundruledid. 0 row(s)
    saving table inboundrule. 3 row(s)
    saving table externalline. 3 row(s)
    saving table outboundrule. 3 row(s)
    saving table dnrange2rule. 0 row(s)
    saving table rule2line. 0 row(s)
    saving table ringgroup. 1 row(s)
    saving table ringgroup2dn. 2 row(s)
    saving table queue. 0 row(s)
    saving table queue2dn. 0 row(s)
    saving table ivr. 0 row(s)
    saving table ivrmenuitem. 0 row(s)
    saving table sysfile. 0 row(s)
    saving table ivrmidn. 0 row(s)
    saving table ivrmireturn. 0 row(s)
    saving table ivrmimenu. 0 row(s)
    saving table ivrmisave. 0 row(s)
    saving table ivrmilisten. 0 row(s)
    saving table ivrmicbn. 0 row(s)
    saving table parameter. 19 row(s)
    saving table calendar. 0 row(s)
    saving table holiday. 0 row(s)
    saving table gwpar2gateway. 48 row(s)
    saving table gatewaytplvalue. 0 row(s)
    and thats it. i would of thought it would have said save to or something
  4. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    You should then get the bar at the top of internet explorer asking if you want to download the file, click save then a window should appear asking where to save the file
    Stephen
  5. spec
    Sep 8, 2006
    51
    thanks that did it because i had that intranet bar still up there didn't see that
    thanks
  6. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    so, is now working properly?
    cheers
  7. spec
    Sep 8, 2006
    51
    yep now working properly
    thanks
