Where do I submit bugs found in Version 15 (Linux)
Discussion in '3CX Phone System - General' started by JimbobNZ, Dec 2, 2016.
Tags:
  1. JimbobNZ
    Dec 2, 2016
    13
    So far I have found three bugs with 3CX v15 for Linux, which could be quite major. Where do i submit them?
  2. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Hi Thanks for your feedback
    Go ahead and submit them here. Important to specify the version so we can report back when and in which version they are fixed.
    You can change the repository if you want by adding "beta" to 3cxpbx in the url
    echo "deb http://downloads.3cx.com/downloads/3cxpbxbeta/ /" | tee /etc/apt/sources.list.d/3cxpbx.list
    When you do this you will get the next update that will be final. (We are making another beta update today).
    Update to this.
    Check to see whether the issues you found are still present in this version.
